Neutral Safety/Steering Column/Side Mirrors
Old Nov 19, 2011 | 06:41 PM
yeldogt's Avatar
That is a strange combination?
How did you force the transmission? The car does have an interlock with with the key and brake pedal .....are your brake lights working?
The mirror control also has a "one touch" system when you move the gear selector into reverse -- it will dip the right mirror to see the curb - to aid in parking ------ so if you have a selector switch problem may be that is doing something wit system module -- that is the only thing I can thing of that links the mirrors - wheel memory and the gear selector.
Old Nov 19, 2011 | 07:05 PM
Boomer from Boston's Avatar
You might check the fuses in the left heelboard panel. Fuses 5 and 7 feed into the body processor module, and can affect those functions. Maybe fuse 8 as well.
DFW
Jul 27, 2020 02:44 PM
mikiep
Dec 20, 2019 07:37 PM
hkmcmast
Nov 29, 2015 06:56 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
hughey
Oct 2, 2015 05:17 AM
