new member from leighton buzzard
Old Mar 24, 2014 | 03:23 PM
matu88's Avatar
Default new member from leighton buzzard
Hi all, hope your all fault free with your cars...I finally own a jag my brother also has a jaguar xj8 with the conversion to a 4.2 v8 and we also own another jaguar sov 3.2 v8 2001 that we use for spares, now I own the executive xj8 3.2 2001, great car and lovely perlecent greeny colour, only it won't start lol, I know this is a very common issue as I have seen allot of threads about it, so I will start with what condition I brought it in,
Parked in the corner at a car dealers house covered in moss, my brother brought it for me for £500 as a project to bring it back to life, the dealer said it use to run but the battery died and now it won't start, so I trailered it home and begun diagnosis...I can smell fuel in the cylinders and I can hear the fuel pump hum away at the turn of the key, it cranks well and fast, but don't have a spark, so I changed the crank shaft sensor and still no spark, cleaned all earths, no change, checked each fuse and all are fine, changed all relays, still nothing, checked pin 1 and 4 on the coil plugs and there's power with ignision on or of, so changed all coils and still nothing,changed all spark plugs and still nothing, checked the big plug on the back of the bulk head and is very clean, swapped ecm and a small black unit under that and still nothing, every now and then when the battery gets low from cranking I get the fault codes on the dash saying Trac not available and some other things but goes away once iv re-charged the battery, iv read the fault code and only one comes up as p1000 but can't find any info on that, both key fobs UN lock and lock the car and I have 3 keys 1 being green and they all crank the car but still no spark, the car has done 140k with 2 former keepers and full jaguar service history,
Any advice from you guys would be much appreciated ..
Sorry if I posted my problem in the wrong area...
THANK YOU ALL
Matt
Old Mar 29, 2014 | 12:10 PM
scm's Avatar
scm
P1000 just tells you it hasn't completed the full startup diagnostic checks (OBD Systems Readiness Test Not Complete) - you get P1111 when they're complete.
Old Mar 29, 2014 | 12:16 PM
Matt, I've moved your post to the X308 tech section.
Hopefully someone can come up with some ideas for you.
Old Mar 30, 2014 | 02:46 PM
matu88's Avatar
Ok thanks
Old Mar 30, 2014 | 02:54 PM
matu88's Avatar
Today I removed all connections and cleaned of any corosion, there was quite a bit but I still have no spark, next I removed the fuse boxes and cleaned connections underneath, still nothing, I tried swapping the module over behind the glove box and still made no difference, I then removed most of the dash and checked wiring and connections even under the steering colum, and tried a brand new battery with a jumper attatched and still no spark, I'm running out of ideas now and would really appreciate any advice to get it started,
Old Mar 30, 2014 | 04:01 PM
Sean B's Avatar
There's a security feature that may need resetting within the ecu/bcm. This may have been tripped when being moved.
It may be as well to replace all the car's original modules then a trip to your local specialist with IDS or Autologic to reset it.
Old Mar 31, 2014 | 04:32 AM
matu88's Avatar
I think iv changed every module now, is there any way I can reset it my self, also if that was tripped would it still crank over?
Old Mar 31, 2014 | 07:56 AM
danielsand's Avatar
As Sean said. "Swapping" ECU will not help you. You need Autologic/IDS to reprogram. And the symptoms you are describing are right on. The car will crank as usual, but no ignition. Call on some Indys in your area, and ask how much they would charge (prices vary WILDLY in the States). That's your best option.
Report back when you sort it out. Good luck.
Old Mar 31, 2014 | 01:58 PM
Stu 1986's Avatar
Just a thought, it's not cylinder washed is it? You mentioned could smell petrol and with you constantly cranking its pumping fuel into the engine.
Old Mar 31, 2014 | 03:36 PM
danielsand's Avatar
The wash does have a spark, it's the compression it's lacking. (and here I assume that OP checked for spark with the plugs removed) By now (no spark and constant cranking), it's washed for sure.
Old Apr 1, 2014 | 09:52 AM
matu88's Avatar
Thanks for the replys, when I checked for a spark I removed a coil of each side and used brand new spark plugs to check for a spark by putting them in the removed coils, earthing them and having my brother turn the engine over,
I'll phone around a few shops for prices on the reprogram, should I put the original ecm in or leave the one in that I swapped with?
Thanks for all your help...
Old Apr 1, 2014 | 04:34 PM
Stu 1986's Avatar
Have you checked to see if it is or isn't cylinder wash?
trickeyM
Oct 4, 2015 05:43 PM
Clare Jennings
rhemler
Oct 4, 2015 05:37 PM
Spazzzzzzzzzy
Newark Nj Gang
Oct 2, 2015 02:39 PM
