New TPS floors-it on startup!! How do I recalibrate/reset the TPS (and do I need to?)
Old Feb 17, 2011 | 11:47 AM
DavidN's Avatar
Based on my bad experiences I don't recommend messing with the TPS!
But you asked - The TPS is fixed to the TB with 2 screws (Star-headed, kind of Torx-headed just with a few more lobes).
If you loosen these screws you can adjust (turn) the TPS which changes the position of the butterfly in the TB.
My advice would be to let a dealership do te calibration/adjustment.
David
Old Feb 17, 2011 | 12:31 PM
avos's Avatar
There is not much calibration you can do, but you can move the TPS unit slightly. The ECU will no go below a certain voltage to control the idle, so chances are that when you turn it anti clock wise a bit it could help.
Old Feb 17, 2011 | 02:59 PM
SuperSport's Avatar
Originally Posted by DavidN
As I wrote - Shop said everything fine. Idiots... (sorry).
Does not seem fine to me. I know these cars are supposed to let off lightly, instead of abruptly, but it sounds like yours takes a bit too long. Mine lets off smooth, but definitely slows down properly.
Originally Posted by vdpnyc
re: throttle cable adjustment held in place via plastic-tie, holy cow, I was sure a previous owner had messed with the car - really lame that it comes from the factory held in place like that, a simple screw in threaded hole would be the proper way to engineer this...
I thought the EXACT same thing, until I realized it's 12 years old and still working as designed. Maybe it's ok.
Me personally, I would definitely mark the position and TRY it. You don't have much to loose. Just do it in very small increments and move it back if ineffective.
But, that's just me. Dive in head first and hope I don't crack my head open in an empty pool.
SD96XJ6L
Jan 12, 2022 04:30 AM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Lumppy47
XJ40 ( XJ81 )
Nov 8, 2015 08:19 AM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
