Newbie looking for some help with window switch
Old Jan 24, 2010 | 11:38 PM
JWT's Avatar
JWT
Jonpiero, Another member may have better advice, but I had a similar problem, where my window would go down, but not up. I had to purchase a new switch cluster. I could only get the window up by bypassing the switch. The switch is fairly easy to replace, once you lift off the door panel. If you try a new switch, try to get your part supplier to allow a return, should it turn out to be something else. (the worst they can say is... no)
PS... I think I read in my manual that the negative terminal should be removed for a minimum of 30 seconds, to protect the electronics, I assume. Leave it disconnected a bit longer to be safe.
rentzoo
Nov 10, 2015 04:56 PM
LnrB
Sep 18, 2015 09:48 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
jagent
Sep 12, 2015 09:10 AM
1964Daimler
Sep 9, 2015 11:28 AM
