No back up lights or Rear Fog
Old Feb 11, 2015 | 06:28 PM
coastaljag98's Avatar
Default No back up lights or Rear Fog
just checked fuses and nothing looks blown in the boot fuse panel. Anything else to check or is this the dreaded SCLM? My other Jag the brake lights went and I rigged, but this one everything was tip top and now this.....any suggestions appreciated guys!
Old Feb 11, 2015 | 11:59 PM
jimlombardi's Avatar
Looks like 2 possibilities:
I know you checked all the fuses, but try replacing fuse number 1 (10 amp fuse) in the trunk (luggage) fusebox.
Luggage fusebox - fuses table:
The relays in the trunk fusebox diagram has shows "heated rear window" R2 also "tail and number plate lamps" R3.
If that does fix it, then it probably is the SCLM module (Rear Fog Lamp Supply BT1-4 pin -- wire is orange with yellow stripe) and (Reverse Lamp Supply BT1-5 pin -- wire is orange with green stripe).
Jim Lombardi
Old Feb 13, 2015 | 08:46 AM
Jim Lombardi
I did try the fuse number 1 but did not look at the relays. Will look tonight.
Old Feb 13, 2015 | 08:15 PM
mikebaker3's Avatar
On the R/H hinge, remove the plastic cover and examine the wire harness. It is very common for the wires to break over time. Think of it like bending a paper clip back and forth over and over, the wire hardens and eventually breaks.
BrentGardner
29
Dec 16, 2024 12:13 AM
tonydbaker
Aug 30, 2015 11:02 PM
cheaperts
Aug 30, 2015 06:48 PM
Spikepaga
Aug 30, 2015 12:59 PM
Jandreu
Aug 29, 2015 07:31 PM
