Noise when exiting vehicle,
Old Oct 5, 2018 | 09:21 PM
King Charles's Avatar
Default Noise when exiting vehicle,
When I exit the driver's seat & step/hop out the car I get a loud creak emanating from the middle to the rear of the car, what suspension component could this be ?! I suspect corrosion or mud/debris from all the hurricane rain etc. I'm having the rear wheel bearing done this coming week & while they have it I want them to lube up whatever it up is underneath there.
Old Oct 6, 2018 | 03:17 PM
Sean B's Avatar
trans/prop UJ flanges?
Old Oct 6, 2018 | 03:48 PM
Highhorse's Avatar
Did you deflate the pontoons off of her first....lol
Check these....
Old Oct 6, 2018 | 03:51 PM
avern1's Avatar
You might want to check and see if the carrier bearing mount for the drive shaft has come loose or is corroded.
Old Oct 6, 2018 | 04:32 PM
Stu 1986's Avatar
Are you using the handbrake whilst parking? It could just be the vehicle weight shifting against the brakes as you exit, causing the load to differ.
Old Oct 6, 2018 | 08:00 PM
No handbrake usage @ all. I will get the guys to give it a look Monday.
Thanks !
Old Oct 8, 2018 | 11:33 AM
Shop just called, rear springs were a bit compressed & a couple coils were in contact w/ each other. They resat them & dressed w/ anti-seize fluid, back quiet.
al_roethlisberger
Dec 23, 2016 06:43 AM
webshark
Oct 22, 2016 06:01 PM
jaggermang
Feb 10, 2015 03:28 PM
jaguarcraver
Jun 7, 2013 02:51 PM
97X300VP
Aug 3, 2011 03:02 PM
