Noisy fuel injectors
Old Nov 22, 2013 | 02:10 PM
Jhartz's Avatar
Default Noisy fuel injectors
Getting some ticking noise from the engine (4.0 01 308). Usual clicking and tapping at startup, from VVT; this new noise sounds more rod knock. new secondary tensioners, so I was concerned it might be primaries or loose secondary chain.
Using a stethoscope, there is normal reciprocating whines from intake manifold, exhaust manifold, VVTs, water pumps, alternator, AC, PS. loudest on cross over pipe behind thermostat tower. Pulled the plastic shrouds and noise emanating along injector rails; most from injectors on port side -- loudest is # 8 (B4, left bank, furthest aft), with # 7 second loudest. Comes and goes, gone above 1500 RPM.
No codes, trims are normal. Added some fuel system cleaner: hopeful..
Any thoughts/guidance?
Old Nov 22, 2013 | 02:55 PM
princemarko's Avatar
Check for loose spark plugs
Old Nov 22, 2013 | 03:02 PM
Jhartz's Avatar
Thanks, but no. Not this time. Torqued on the money. I put the stethoscope on the injectors, the noise is there, no where else!
XKE73EIconverter
Sep 26, 2015 10:21 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
DaveInVA
Sep 25, 2015 04:43 PM
reb1999
Sep 25, 2015 10:00 AM
Bcrary3
Sep 11, 2015 10:36 AM
