Not Starting Again
Old May 1, 2008 | 07:56 AM
newjagowner98xj8's Avatar
Default Not Starting Again
Ok, I have replaced the fuel pump, and filter and the 98 XJ8 worked great.
This morning go to crank her up and I can her the engine wanting to turn and turn so from pervious advice I crank down on the starter for 30 seconds. It kept reving up and reving down but never starting. The check engine light is on. I backed off the starter because I started to smell something funny.
I just bought the car 2 months ago and have put 4k miles on it (63K total). ImI over reacting by wanting to sell it? Any help would be much appreciated.
Old May 1, 2008 | 06:55 PM
jag_genius's Avatar
Default RE: Not Starting Again
any fuel pressure?
Old May 1, 2008 | 06:56 PM
FactoryJaguarTech's Avatar
You are overreacting. What was the funny smell? If you could feel it starting to kick over, keep foot all the way down on the gas and when it kicks, let off about half way on the throttle. Keep doing this, but do not let go of the key. Is it possible that you are smelling fuel?
Old May 1, 2008 | 07:07 PM
jag_genius's Avatar
i have sometimes smelled a burning starter.. but she can take a beating and still work..
Old May 1, 2008 | 08:09 PM
It kicked over tonight. The wife gave it some gas while i was looking under the hood and it kicked over. Thanks guys for all the help.What would have caused this and how do I prevent it if possible? Also when driving it the jag kinda rocks around 50mph when i stomp on it it. However, when it warms up it does not do that. Any thoughts
Old May 2, 2008 | 08:03 PM
jag_genius's Avatar
may have beenflooded or may have slight fuel problem.. try not giving it a cold start then shut it off. they tend not to like that and flood.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
