O ring/seal for throttle body
Old Nov 21, 2012 | 10:42 PM
coastaljag98's Avatar
Default O ring/seal for throttle body
looking for a part number or place to get a new rubber gasket or o-ring for the top of the throttle body where the air cleaner hose attatches. Mine has been gone for a long time and I get RP and P0174 once in awhile so going to try replacing that and see if that takes care of the issue. Then I guess the upstream o2 sensor for bank 2. Anyone know what the seal or gasket is called?
Old Dec 31, 2012 | 07:32 PM
bump...
Old Dec 31, 2012 | 08:08 PM
jimlombardi's Avatar
The part number is NJA3554AA - Air pipe seal (also called Air Pipe Duct Seal (AIR INTAKE DUCT SEAL TO THROTTLE BODY)
Gaudin Jaguar Parts online shows retail price of $32.45 and discounted price of $28.39 plus $14.95 shipping.
You might call Jaguar of Greenville in South Carolina - they give forum members a discount and free shipping on purchase $25 or more.
Jim Lombardi
Old Oct 24, 2019 | 08:13 PM
rogers1511's Avatar
Originally Posted by NBCat
I believe the service part is sold separately by JLR under the part number NJA3554AA.
Have the bloke at the Jaguar agency check this part number for you. Should be about £36.47 inc Vat.
NJA3554AA it's not the correct part . The seal is not sold separately by the dealership you have to buy the entire tee at $800. Or more. I ordered the part above anyway to check it out and it is definitely not a fit.!
I also ordered the thicker reducer also shown above in this forum from. Amazon but in MY OPINION it would not have sealed as well as the home depot softer coupling... I just thought it was too rigid. It would also have been harder to install and would make it harder to align the two intake ducts to the top of the tee.
I was able to find the coupling from Home Depot that worked perfectly. I also placed a hot soldering iron on it and then also on the original part. The original OEM part melted much faster so I know the Home Depot coupling has a higher melting temperature. Cost me 100th the cost at $8 and some cents. I've driven the car now on two four and a half hour trips in hot weather and examined the coupling and it is fine.
This is a photo of the original part from home depot obviously you do not use the metal housing. The two inner diameter sizes are perfect to to slide over the T duct and the intake duct.
Old Oct 24, 2019 | 09:35 PM
M. Stojanovic's Avatar
Originally Posted by rogers1511
NJA3554AA it's not the correct part I ordered it and it is definitely not a fit.!..how could it..just look at it.
Probably because NJA3554AA is for X308 and your car/engine appears to be another model.
klfong
Oct 22, 2019 05:17 AM
Gerard Radimaker
Mar 14, 2019 05:58 PM
Andre
Aug 9, 2014 08:31 AM
MK2
Jul 11, 2014 08:12 PM
slmskrs
Jun 25, 2013 12:31 AM
