OBD can't see fault codes even when connected
Old Sep 15, 2012 | 10:15 AM
Estilian's Avatar
Default OBD can't see fault codes even when connected (Resolved)
Today I found out that my OBDII to USB module doesn't retrieve information about fault codes from the car's ECU. I tried with several software - all of them are able to connect the car, to preview live data from different sensors, but always shows up that there is no active or stored fault codes... The problem is that I accidentally switched on Drive while the car was lifted and the ABS and ASC faults appeared on the dashboard... and now I'm unable to clean them.
My OBDII reader is ELM 327 ver. 1.6. and it looks like this one:
Old Sep 15, 2012 | 11:01 AM
RJ237's Avatar
The problem is that ABS codes are jaguar specific and generic instruments can't read them. You need to have a shop with Jaguar software clear them.
RJ__________
97 XK8 86K mi
Old Sep 15, 2012 | 11:43 AM
Sean B's Avatar
Take it for a drive, they should clear if there isn't a problem
Old Sep 15, 2012 | 03:39 PM
Estilian's Avatar
Yes it did Thank you Sean
trosty
26
Dec 18, 2022 06:40 PM
Jpav27
Jul 31, 2022 06:43 AM
skadmiri1
Sep 9, 2015 11:27 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
