Oil grade plz
Old Jul 2, 2014 | 01:54 PM
L80ous's Avatar
Default Oil grade plz
I searched the forum and this may seem like a daft question but what sort of oil can I use to top up my XJR X308.
I normally just have my car serviced but I need a topup and Ive only covered 4.5k miles since my last oil change
I have lots of 0-40W Fully Synthetic around I use for my Civic Type R, could I use this?
Old Jul 2, 2014 | 02:43 PM
gabrielbecheanu's Avatar
Hi
I leave in Constanta Romania near to the sea, in winter we have -15 celsius for a few days, normally we have -5 so for me 5w40 is ok. I do not know how cold is in your area but 5w30 or 5w40 will be very good. I use BMW oil, inside the bottle is Castrol. Jaguar use for this engine Castrol product. Castrol oil in Romania is not so good, i do not know where is made so i buy all the time BMW oil if i want Castrol products. In the past ten years in my last car a BMW i use this oil. So in time this product show me how good it is.
Old Jul 2, 2014 | 04:28 PM
Mikey's Avatar
Your owner's manual will list all recommended oil viscosities and types, according to ambient temperatures.
Old Jul 4, 2014 | 02:51 AM
xjay8's Avatar
The standard factory reccomendation is full syn. 5W40
As you are running an XJR with 4.0 litre engine without the VVT units that a normally aspirated 4.0 litre has, you can try the 0W40 in very cold weather but I wouldn't suggest running it in normal temps and definately not in the warmer months....these 0 oils are designed for modern 'eco' engines.
Castrol Edge is the preferred oil and you can go up to 10W50 during the warmer months.
O type oils give rapid drain back into the sump and as most engine wear is caused by cold start up and short trips, it's not a good idea to use them in these engines.
Stick to the factory reccomendations....they did a lot of R&D on this for a reason ;o]
Old Jul 4, 2014 | 03:10 AM
L80ous's Avatar
Stuck some 5W-40 in her, took just over a litre as well to get to full, she's happy again now.
kthrash
Feb 25, 2019 10:20 AM
jagtoes
Apr 22, 2016 07:37 AM
caldoofy
Sep 28, 2015 08:43 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
