Oil leaking from Air intake tube
Old May 9, 2022 | 09:10 PM
98Jagxjr's Avatar
Default Oil leaking from Air intake tube
I have a 98XJR with 105,600 miles, Recently bought it and exhibiting a few issues the main concerning issue If”a engine oil leaking from
Crank case breather hose Leaking into air intake tube and covering my driveway with oil.
This is after driving the car Hard but dose leak oil in intake But not. as bad. What dose this mean and what do I do ?
Old May 9, 2022 | 09:32 PM
motorcarman's Avatar
Likely a NIKASIL engine problem but................
Maybe just a clogged 'part-load-breather'?
File Type: pdf
Old May 9, 2022 | 10:17 PM
98Jagxjr's Avatar
Thank you for the information I will definitely try cleaning out tomorrow but if I still Encounter the same issue what would I do to prevent oil coming out of the intake and that amount?
Old May 10, 2022 | 08:44 AM
Oil catchcan or replace the engine!
Old May 10, 2022 | 07:11 PM
98Jagxjr's Avatar
okay, So does this mean I have a bad engine even though I put the catch can on the vehicle just really confused about this nikasil engine.
Here’s what I’m dealing with 😫
rothwell
May 27, 2019 01:05 PM
NikolaiDiqnov
Sep 19, 2014 02:44 AM
03Xtype
41
Feb 19, 2012 02:55 PM
skanoski
Sep 14, 2010 11:35 AM
xj8xj8
Nov 9, 2009 09:08 AM
