Overhead console: walnut upgrade completed
Old Dec 12, 2012 | 05:13 AM
Vector's Avatar
Originally Posted by plums
I have to swap my Homelink unit because training the unit would involve waiting to borrow a working remote.
You can program the Home Link in the Jag without a remote. Just push the "learn" button on your opener, usually a red button, and then push the Home Link button of your choice in the Jag twice within 30 seconds.
Vector
Old Dec 12, 2012 | 05:22 AM
plums's Avatar
Older commercial unit ... no "learn" button and encased to prevent tampering.
Old Dec 12, 2012 | 07:21 PM
JaguarXJR02's Avatar
Originally Posted by Vector
I swapped mine today with a nice complete unit from Ebay. Looks very nice and the swap was easy, I just had to re-program the Home Link garage door opener.
Vector
excellent, it's a much nicer part than the tan plastic
Old Dec 13, 2012 | 12:32 AM
Ipc838's Avatar
Check out Jaguar Classic Parts, they sell the wood trim piece
for 35 GBP.
Old Aug 15, 2019 | 01:57 PM
King Charles's Avatar
for 35 GBP.
Do you have a link, thanks.
Old Aug 15, 2019 | 03:36 PM
Carnival Kid's Avatar
He may not hear you KC, that was 7 years ago..............
But here's a current ebay ad for $58 US
https://www.ebay.com/itm/JAGUAR-VAND...ty!96073!US!-1
Old Aug 15, 2019 | 03:40 PM
Mine's perfect I just want the wood trim.
Old Aug 15, 2019 | 06:05 PM
  #28
The three piece dash set? Or the door trims. Or both?
Old Aug 15, 2019 | 07:53 PM
Old Oct 15, 2019 | 10:32 PM
  #30
Doing this next !
Old Oct 16, 2019 | 11:03 AM
  #31
grantorino62's Avatar
Did this mod right after I bought mine. Used black RTV to secure it. I found it in a wreck. Cost $5.00 if I recall.
Old Oct 16, 2019 | 12:01 PM
  #32
Vegas_Jag's Avatar
Just replaced mine with the wooden one, I have a yard with lots of Jags, got mine for $2.
Old Oct 25, 2019 | 10:50 AM
  #33
aquifer's Avatar
This thread inspired me to do this mod on my '98 XJR. I had a little more of a challenge, in that the early 98 XJR's had extremely dark wood trim that was not installed on any other X308 to my knowledge, and was not continued very long. I found a veneer piece on ebay from a VDP, and I sent it to Madera Concepts in California where they installed new veneer to match my original wood grain, and then stained it to match the dark original. During my restoration process, I sent all my interior trim to Madera and they did a fantastic job, as they did with this piece.
I'll try to remember to take a picture of the overhead console with the new wood veneer piece, and post it here. I really think the dark wood trim looks stunning, and I'm not sure why they didn't use it very long. I had not thought of doing this modification until I saw this post a while back. It really spiffed up the overhead console!
Old Oct 25, 2019 | 11:08 AM
  #34
Doing this next !
Purchased a wood trim overhead console, seller couldn't recall what trim of car it came from, but if not SDZ I'll just remove the wood & add to mine. Wood's a spot on match for my veneer, burl pattern & hue. On the way from eBay !
Old Oct 25, 2019 | 01:32 PM
  #35
Vegas_Jag's Avatar
Mine is 2000, has a Phillips screw to hold in place, others have a plastic screw in type, or you can take it apart!
Old Oct 25, 2019 | 02:26 PM
  #36
aquifer's Avatar
Here is a picture of mine. I also had them do the little wood piece on the back of the console. The USB port is wired to my alpine head unit.
Old Apr 14, 2020 | 03:34 PM
  #37
BigAlBre's Avatar
Dis any XK8's come with wood on the overhead console?
Old Apr 14, 2020 | 03:36 PM
  #38
BigAlBre's Avatar
BTW I'm taking the car to the tuner 10:00 Thursday morning....can't wait to see the bugs cleared up....and smooth running
Old Apr 27, 2021 | 12:03 PM
  #39
Elmo1544's Avatar
Did this same swap out today. There is a plastic lock screw in the sun glass compartment that allows you to drop the whole module. Then one connector plug to release the power connector. After that just gently pry up on the old panel. There are about four small bent metal tabs that need to be pushed in on the bottom of the panel and sides. I used some wide putty knives to spread the pressure and not break the flat panel.
I had to bend in the metal tabs to get them to reseat when putting the new walnut panel back in. I used the residual glue (like credit card glue) to reapply the new walnut panel. Everything looks good and works.
Old Aug 4, 2022 | 09:42 AM
  #40
Quadcammer's Avatar
I just did this upgrade too and just as a reference, the X300 wood insert fits the x308 perfectly. As an added bonus, the sunglass holder in the x300 used a leather/vinyl piece instead of cloth on the inside, so it looks a little bit nicer. I just removed the wood and the sunglass holder from the x300 unit and installed onto my original console.
