P1631 code, failsafe limp mode
Old Jul 15, 2018 | 08:27 PM
gokaht's Avatar
Default P1631 code, failsafe limp mode
Hello, first time post, long time lurker.
I have a 2003 XJR that keeps giving me a failsafe, limp mode and P1631 code. Usually happens after 40+ miles of driving, happens quicker and more frequently in warmer weather, almost immediately on hotter days.
Clearing codes with a handheld and waiting 30s-1 min allows you to drive again, sometimes for a few minutes, sometimes a few feet.
Worst instance it would crank, stumble
and stall. 90+ degree day, car in the sun. Had to remove the ecu and put in AC. Plugged back in and
made it 15-20 miles before it went out again.
Suspected a short in the ecu that flares up with heat but board looks perfect. Any ideas?
Old Jul 16, 2018 | 10:56 AM
Sean B's Avatar
P1631 relates to a faulty throttle control relay, located in the ECM box under the hood, looks to be the 3rd along from the outside of the car. A dying relay would go faulty with heat - more doubtful is the ECM.
Switch the relay out for a new one.
Hope this helps.
Old Jul 16, 2018 | 12:18 PM
gokaht's Avatar
Forgot to add - that’s what I found when googling the code - not a lot of posts about it - I swapped relays twice to make sure it didn’t change. Definitely heat related - thinking g a failing ecu box fan may be the root cause...
Old Jul 24, 2018 | 07:35 AM
gokaht's Avatar
Update - the small pc style fan that blows air out of the ecu box didn’t seem to be moving much air. I wired a larger pc fan in and it’s pushing a LOT more air out. Made it home yesterday with no failsafe or faults - fingers crossed!
Old Sep 13, 2018 | 06:10 PM
gokaht's Avatar
Another update. Larger fan did not help. What else could it be??
Old Sep 13, 2018 | 06:26 PM
Highhorse's Avatar
Its probably not going to be a direct answer, you'll have to research it some more. Try this (bookmark it also)... JagRepair.com - Jaguar Repair Information Resource ...you can do a search of the electrical diagram, download and review as you determine any faults. I wouldn't stop if you find a fault, be sure to trace it out for more or you'll be cussing yourself thinking you fixed the wrong thing when it could be multiple things.
Raider#01
Jul 4, 2018 06:14 PM
VAXKR
Jun 23, 2017 03:56 PM
Mimmo
May 7, 2012 10:17 AM
ndrush
Apr 1, 2012 04:34 AM
Lee DaMet
Jun 9, 2011 11:09 AM
