Passenger door ajar
Old Oct 23, 2024 | 06:59 PM
3timejag's Avatar
Default Passenger door ajar
All of a sudden my “passenger door ajar” light will not go out….and the car is beeping when I try and remotely lock it. I can still lock with key though.
Any help/suggestions are greatly appreciated!
Old Oct 23, 2024 | 07:16 PM
Addicted2boost's Avatar
Scott, it sounds like you have a bad microswitch in your door lock assembly. If you open the door and using a thin screwdriver, you could try opening and closing the latch with the screwdriver in one hand and using your other hand to keep the door handle in the open position while operating the latch multiple times. I suppose you could try a hard reset just for the fun of it to see if that helps but, if it doesn’t, you’ll need to remove the door lock assembly and either clean/lubricate the internal mechanism or see if the microswitch is loose.
Old Oct 23, 2024 | 07:25 PM
3timejag's Avatar
Thank you, will try that!- wish I knew which damn door it was lol!
Old Oct 23, 2024 | 09:28 PM
3timejag's Avatar
yes, Scott….It’s all good brother, you’ve helped me many times over the years, we’re good!
Old Oct 23, 2024 | 09:34 PM
If you started it up at night but left the headlights in the off position, you should see a puddle light in the interior door panel still lit up. I suppose it depends if that puddle light bulb isn’t burned out also.
Old Oct 24, 2024 | 02:50 PM
3timejag's Avatar
Thank you for the “puddle light” trick….although it WAS burned out, when I replaced the bulb, it still didn’t come on. The other two were triggering when I engaged the latch, so I knew it was the one.
Thanks again, you’re always of great help!
Scott
khaledo0ov
Oct 30, 2020 03:36 PM
Kbrown52
XF (X260)
Jun 30, 2020 12:38 PM
GeorgioTsukolius
Aug 21, 2016 01:24 PM
v6-ben
Jul 19, 2013 01:36 PM
