Pinging Sound VS Timing Chain Sound
Old May 14, 2014 | 11:51 AM
62sunbeam's Avatar
Default Pinging Sound VS Timing Chain Sound
I'm trying to figure out what I'm hearing.
On acceleration I hear what sounds like pinging.
It doesn't always happen and it might even go away with better gas. I always use premium but who knows what I'm actually getting
Anyway, will failing/worn tensioners sound like this and only when under load like this? The engine is quiet upon cold start up.
What symptoms does a worn lower tensioner sound like?
I want to make sure I'm chasing the right issue.
Eric
Old May 14, 2014 | 01:38 PM
sparkenzap's Avatar
If you have any doubt (which you obviously do or you wouldn't have posted ), and you don't know that you have Gen III tensioners, I would suggest you have a look before driving it any more. The risk for a major engine disaster is just too great to fool around wondering.
By the way- It is not "worn tensioners" you should worry about... the tensioners have a propensity for sudden mechanical failure!
SD96XJ6L
Jan 12, 2022 04:30 AM
PMKimpton
Aug 3, 2019 08:22 PM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
dcvickers
Sep 2, 2015 06:14 PM
