Power Arial Fixed Itself!
Old Mar 21, 2013 | 04:38 PM
OldMike's Avatar
Default Power Arial Fixed Itself!
Several months aog, while in a brief moment of brain malfunction, I decided to clean my aerial shaft -- it had been sticking once in a while either on the way up or on the way down. I took the base nut off for no apparent reason and sprayed the shaft with white grease and wiped it down good. After putting it back together, I noticed that it would go down just fine but when going up it would get to the max position and motor would just grind away for a few seconds (seemed like hours!) making a loud, loud noise that was easily heard inside the car and outside, too.
I decided to forget about it and wait until it quit working and then take it apart and re-run the plastic cable or replace it or whatever it needed!
Well, I just realized the other day that it no longer makes that obnoxious noise! It works perfectly - up and down! It fixed itself!
Love this kind of DIY project! LOL
Old Mar 21, 2013 | 08:07 PM
coastaljag98's Avatar
The white lithium grease probably worked it's way into the plastic gears and now it's happy
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
AL NZ
Sep 4, 2015 08:39 PM
