Power steering fluid?
Old Sep 30, 2014 | 04:55 PM
badger2196's Avatar
Default Power steering fluid?
I'm replacing my power steering pump soon and I'm confused about the type of power steering fluid that I need. The owner's manual says to use Dextron III but I can't find any Dextron III power steering fluid, only tranny fluid. I talked to the local O'Reilly's guys about it and they told me that "any of the power steering fluids should be fine". Are they right? If not, what's the correct fluid to use?
Old Sep 30, 2014 | 05:11 PM
yeldogt's Avatar
I think the actual spec is ESSO 320 ... now Mobil 320 ....... If you get it from the dealer. It has been a long time since I have had to get any
I am going from memory
Old Sep 30, 2014 | 05:36 PM
plums's Avatar
Power steering fluid is not correct.
If you cannot find Dexron III, then find ATF that is Dexron III compatible.
One example is Valvoline Maxlife Dex/Merc available at any Walmart:
Valvoline.com > Products > MaxLife > Automatic Transmission Fluid MaxLife > MaxLife® DEX/MERC ATF
Old Oct 1, 2014 | 03:32 PM
avt007's Avatar
I use Dexron III ATF from NAPA.
Old Oct 1, 2014 | 06:50 PM
larney's Avatar
Similar to the old Mercury cars. My 70 Cougar uses Type F trans fluid in both the trans and power steering.
sogood
Sep 15, 2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
