Puting an aj27 into a 98 xjr
Old Oct 9, 2016 | 04:22 PM
Dhighlife27's Avatar
Default Puting an aj27 into a 98 xjr
So i recently put a 2001 aj27 engine into my 1998 jaguar xjr .
I am aware that the lobes on the cams are differnt , so im wondering if i need to only swap the lobes from the aj26 engine or the whole camshaft . Also if someone has a step by step guid e to doing this and how to correctly reset the timing i would apriciate it . Also when puting an aj27 engine into a 1998 xjr that came with the aj26 , are there any other parts i need to replace , swap from the old engine , or remove . First jag so please be detailed , pictures if possible.
Old Oct 9, 2016 | 04:31 PM
JTsmks's Avatar
I'm pretty sure you can't swap "lobes" camshafts are usually ground as "one piece" so to speak.
Old Oct 9, 2016 | 04:39 PM
Correction* , i ment can i just swap the reluctors on the cams or dose it have to be the whole cam, (inlet cams )
Old Oct 13, 2016 | 09:34 AM
dsnyder586's Avatar
You *can* just swap the reluctors, but I did not have a ton of success trying so I just swapped the cams.
Old Oct 13, 2016 | 02:14 PM
Ok cool , and you swaped both inlet cams right?
LedZepplin
Sep 8, 2016 09:25 PM
ajpeyton
Aug 25, 2016 01:27 PM
Peter Jones
Aug 24, 2016 08:12 PM
JagMan954
Aug 23, 2016 01:48 PM
powerlord
Aug 23, 2016 12:18 PM
