Quick Question front subframe bolt size? and stuff.
Old Feb 16, 2022 | 10:38 AM
JamBar's Avatar
Default Quick Question front subframe bolt size? and stuff.
Hi all
Are the big bolts at the rear of the front subframe 29mm? It's hard to tell other than a 28 is too small and a 30 too big. I am not sure if the heads are a little damaged, or if they are a crossover from the imperial days?
In the process of stripping our 1999 XJ8 4.0 LWB. Sadly the floor is 30% missing due to rot. The front and rear chassis rails are also rotten at the V mounts and over the rear axle. It needs so much welding she is going to rest in peace (pieces). :-(
So we are trying to drop the front subframe out complete with engine and trans (which are good and available if anyone is interested?) Well, it's all going ASAP (due to moving home in 10 days), just keeping a few things as spares for our other X308.
James
Old Feb 16, 2022 | 04:45 PM
nilanium's Avatar
I think those bolt heads are 1 1/8, or close imperial size
JamBar
Mar 11, 2024 07:39 AM
Gino
Aug 21, 2021 01:18 PM
W0ngu
May 27, 2021 04:42 AM
katar83
Oct 20, 2018 03:25 PM
avioni
Sep 5, 2013 07:26 PM
