R-Performance brake hose interchangeability
Old May 20, 2018 | 04:21 AM
xjr2014_de's Avatar
Default R-Performance brake hose interchangeability
Hi gents,
By any chance, does anyone know if the front brake hoses for Brembo brakes of the XJ series is interchangeable with the brake hoses of the XK series?
As the XK hoses (C2N3107) cost almost a third of the price of the XJ hoses (MXD5670BC) it's a tempting idea to replace mine with the XK hoses.
I'd guess that the fittings/connections to the body's brake lines as the ones to the calipers are identical, the difference between the XK and XJ hoses lies in their length, right?
Cheers, Alexander
Old May 20, 2018 | 11:13 AM
Sean B's Avatar
Just a quick answer for now Yes, I have XKR-R braided front lines fitted, a thing I noticed over the XJR - length, a little longer so I get them ziptied. I'll try and confirm part numbers later today...
Old May 20, 2018 | 11:33 AM
xjr2014_de's Avatar
Thanks Sean for your reply! That's awesome! I think the additional length is of no problem, since they can surely ziptied away a bit. The opposite way with the XK Brembo lines being shorter than the XJ lines would be much more of a problem due to more stress on them when turning the wheels.
Thanks a lot and I'm looking forward to hearing from you concerning the correct part no.
Cheers, Alexander
Old May 20, 2018 | 05:04 PM
grandell's Avatar
Goodridge make stainless braided lines for the XK with Brembos too, which is what I've ordered for my conversion, as per everyone's recommendations.
I didn't look at prices for genuine, but the Goodridge's were very well priced.
https://www.goodridge.co.uk/products...nt=31947432775
Old May 20, 2018 | 08:06 PM
xjr2014_de's Avatar
Yeah, I was looking for the Goodridges too. @grandell: Did you use the XK Brembo lines for a XJ or on a XK?
Old May 20, 2018 | 08:19 PM
grandell's Avatar
They will be going on the XJR
tsfo2
Mar 25, 2018 12:30 PM
JagtechOhio
General Tech Help
23
Nov 13, 2017 07:57 AM
Roghatjr
Jan 31, 2011 06:03 AM
mrelezaj
XK120 XK140 XK150
Aug 26, 2010 03:14 AM
