Radiator O Ring
Old May 29, 2016 | 01:16 AM
larney's Avatar
Default Radiator O Ring
Anyone know what the part number or size of the o ring for the plastic tube running into the top left(drivers) side of the radiator? Thanks.
Old May 29, 2016 | 03:28 AM
greverrr's Avatar
I used one from this box when one of my small coolant line o-rings finally totally decayed. Don't recall which one exactly, but it fit and consequently works
225 Piece Nitrile O-Ring Assortment
and yes, nitrile is compatible with ethylene glycol
http://www.documentation.emersonproc...798x012_06.pdf
Old Jun 2, 2016 | 10:02 AM
larney's Avatar
I noticed Harbor freight had a box of assorted O Rings for automotive use. Would these work as well any reason to spend the extra 4 bucks?
180 Piece Viton O-Ring Kit
Old Jun 2, 2016 | 07:55 PM
greverrr's Avatar
Viton is also safe with coolant
Viton Chemical Compatibility Results
Old Jun 2, 2016 | 10:03 PM
nilanium's Avatar
Is it for the s/c radiator or main radiator? I found these for the s/c rad when i was looking for a bleed hose recently, the main radiator may use different o-rings though.
Part no. KSR605001 | O-ring parts from Jaguar Classic Parts UK
EDIT: noticed you have an xj8. same still applies, I'm not sure if the O-ring i have here is the one you need.
springer
Apr 22, 2016 11:05 AM
CoventryFlagship
Apr 20, 2016 05:52 PM
webbeing
Apr 18, 2016 11:46 PM
jagtoes
Apr 15, 2016 06:38 AM
silversurfer1221
Apr 6, 2016 05:26 PM
