Rattle/clatter/knock under low speed load
Old Apr 14, 2014 | 05:05 AM
motorcarsrandy's Avatar
Default Rattle/clatter/knock under low speed load
My 00 XJR has this low speed under load knock/clatter. almost like a detonation noise, but I think not. when taking off slowly under load. thoughts. not overheating. chains and tensioners replaced. Fuel system cleaned. Plugs new.
Im baffled
Some type of belt tensioner noise?
super charger?(Dont know what a bad coupler sounds like)
converter? Def does not sound like mech internal engine noise.
give me what you got.
thx.
Old Apr 14, 2014 | 06:08 AM
plums's Avatar
have you replaced the fuel filter?
otherwise, best guess is that your secondary fuel pump is toast.
Old Apr 14, 2014 | 08:15 AM
New filter was installed when I replace both pumps in December. Runs like a spotted a$$ ape otherwise.
Old Apr 15, 2014 | 07:40 PM
bump
Old Apr 15, 2014 | 08:40 PM
sparkenzap's Avatar
I think I would put a stethescope on the blower snout and listen for similiar but quieter noise at idle.
Old Apr 15, 2014 | 09:44 PM
i'm thinking SC noise. May be hearing a failed coupler in the SC. under just right load spring loaded coupler may be chattering.Took belt off and feel some play in coupler by turning back and forth by hand.
Will listen to bearings tomorrow.
Old Apr 16, 2014 | 08:19 AM
Strangest thing. I noticed a bad SC idler pulley bearing and changed it before I left shop last night. Knocking noise still there low rpm under load. Was getting low on fuel, stopped at Exxon and put in fuel. so far no knock noise...hmmm...I have been using various sources and having this knock with diff suppliers. could be a fluke. I still plan on rebuilding SC Snout.
Bcrary3
Feb 21, 2023 04:29 AM
Forcedair1
Feb 19, 2020 01:51 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
hen555
Sep 7, 2015 11:13 PM
