Rattle at cold startup?
Old Jan 1, 2008 | 08:24 PM
worldpower's Avatar
Default RE: Rattle at cold startup?
its not always the tensioners, i had mine replaced and i still get that rattle upon startup, i just ignore it now.
i think some situations are because of not enough oil pumping through
Old Jan 2, 2008 | 07:32 PM
jag_genius's Avatar
it's not always the secondary ones(the easy ones)
sometimes it's the primary as well .. or worn out sprockets..
Old Jan 12, 2008 | 03:53 PM
worldpower's Avatar
does your mechanic know what to look for? is he experienced with Jags?
Old Jan 12, 2008 | 06:09 PM
FactoryJaguarTech's Avatar
If your mechanic was in there already, what did he have apart? A kit for the tensioners that can be installed in 2 hours? Man if I could do that in 2 hours I would be rich.
It is like an 8 hour job to do tensioners. If you are going in there to do them, do them all. When you half *** it you will be paying again to get things done.
If they were done then I wouldnt worry. As said could be the lack of oil pressure on first start. Look inside the throttle housing and see if you have any oil there. If so the 98 motor probably has some blowby. Most commonly however if the noise exists after tensioners done, VVT units make a rattle on first start.
That may be common only to my area however due to differing climates, different noises can mean different things.
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
millertic
Sep 30, 2015 08:11 PM
