Rear Asteroid widest tire sizes?
Old Feb 28, 2019 | 09:36 AM
PeteyT's Avatar
Default Rear Asteroid widest tire sizes?
What are the widest rear tire sizes I can install on my 2000 XJR Asteroid 18x8s?
Old Feb 28, 2019 | 12:35 PM
Highhorse's Avatar
https://www.jaguarforums.com/forum/t...calculator.php
Old Feb 28, 2019 | 06:33 PM
ericjansen's Avatar
The tire shops are right in this case, the 255's fitted by Jaguar are already on the limit.
You will need wider rims, or staggered with a wider rim on the rear, to allow for wider tires.
Old Feb 28, 2019 | 11:00 PM
M. Stojanovic's Avatar
These are recommended (approved) rim widths, by one of the tyre manufacturers, for various tyre sizes:
Old Mar 1, 2019 | 10:42 AM
Highhorse's Avatar
We have all stated recommended spec tire sizes because going any larger and you lose performance drive ability. Tires have changed regarding ability and reputable tire shops will have the latest info for applications. The x308 is a heavy steel body car (about 5k lbs) and when you go into a corner or brake you put a force load on the sidewall of the tires (both inside and outside of the rim). Which is why certain tires are recommended for certain cars, ...by putting on a wider wheel than the rim size, you are taking the chance of damaging the sidewall and risking wheel damage or perhaps an accident, not to forget to include balancing issues and vibrations.
My VDP(R) has 255/40 18 Michelin Super Sports on Penta rims. I highly recommend not going with any lower than a 40 sidewall, you'll get a stiff, rough ride and it doesn't look good in the wheel well...too much space.
Salem1
Aug 30, 2020 11:27 PM
sunchip
Jan 31, 2016 10:18 AM
platinummaker
Jan 29, 2014 11:58 PM
87jagcatxjs
May 16, 2012 11:16 AM
