Rear bushings - 2000 XJR
Old Dec 6, 2009 | 09:13 AM
mfennell's Avatar
Default Rear bushings - 2000 XJR
At 117k miles, it seems to have a little self-steering issue in the back. I was thinking rr subframe bushings but I see that there are 6 or 8 other bushings that could be contributing. I was suprised this didnt come up much in search. Rubber bushings are normal wear items on BMWs. Two questions:
1. are there any ones in particular i should not bother to replace?
2. the only part number available is the "sport" rr subframe bushing. can I safely assume that is what I'll get, not the comfort (4 hole) version?
Thnks for any thoughts.
Old Dec 7, 2009 | 01:06 PM
H20boy's Avatar
Moved ya over here Mike since you'll get more views as opposed to general tech help.
Good luck!
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
obwoodie
Sep 3, 2015 07:45 PM
