Rear Differential Servicing...How / Where / Questions.
Old Jul 4, 2015 | 01:51 AM
xjrjag's Avatar
Default Rear Differential Servicing...How / Where / Questions.
There are some things that I know and some things that I do not know / unsure of. I have to replace the U joints on the drivers side rear...and while I am at it, I want to replace the fluid in the diff. I have read that there is no drain plug, only a fill plug.
1) Where is the fill plug exactly, and how do I drain / fill the diff?
2) While I'm there, I know there is a differential breather valve located somewhere. Can someone tell me where it is located and the best way to clean it?
3) Lastly, what diff fluid should I use that can be purchased at the local parts store? What weight? 75w90?
Old Jul 4, 2015 | 06:09 AM
hnatten's Avatar
The fill plug is on the rear of the diff quite far down, you will easily see it.
You need to suck the old fluid out with a pump. A cheap hand pump will do just fine.
The breather is on the top near the rear of the diff. Just stick up your hand and you will feel a little cap that should be a bit loose.
The breather takes a 14mm spanner if i remember correctly.
I just replaced my breather as it's a cheap part. But you can probably clean it with some brake cleaner.
I used 75w90 GL-5 oil.
Old Jul 4, 2015 | 09:08 AM
Box's Avatar
Box
Back in `04, Jaguar released a new specification for older models like the X308, which stated it needed to be synthetic, and meet M2C 192A, which is limited slip additive specific, and then specified 75W-140. There seems is a lot of misunderstanding about fluids and weight. 75W-90 and 75W-140 both start as 75W oils. They have viscosity improvers added to give the lubricant high temp viscosities. The 75W-140 actually provides better high heat viscosity, and better protection. As far as getting the old stuff out, many take a small section of copper pipe and bend it into a J to get it to the bottom of the case. Works like a charm.
Old Jul 4, 2015 | 09:34 AM
xjrjag's Avatar
The only plug that I see looks like you stick a socket extension into it to remove it. Is this the correct one?
As for the diff fluid, I dont think I have seen 75w140. I will check the parts stores. I am sure the dealer would charge a pretty penny.
Old Jul 4, 2015 | 09:44 AM
Box's Avatar
Box
I can vouch for Valvoline Synthetic 75W-140. It meets the specs. Any AutoZone has it. And concerning your plug question, yes, you place a ratchet into it.
Old Jul 4, 2015 | 10:18 AM
xjrjag's Avatar
I will look for the Valvoline. What is the diff capacity? 3 quarts?
Also, is that breather valve readily available at the dealer, or is it a special order item? I may just replace it.
Old Jul 13, 2015 | 05:02 AM
Thierry R's Avatar
here is the plug on the differential :
XJ8 rear differentail plug
As you can see , mine was wet as a leak was coming from a dead gasket on the right axle shaft !
Now fixed by replacing bearing(differential sealing ring already fitted on the bearing) +bearing retaining collar+studs
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
danke
Mar 3, 2016 10:57 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
timm525
Sep 8, 2015 07:57 PM
