rear drive side wheel bearing ?? 2000 jag xj8
Old Nov 22, 2012 | 01:14 AM
RidenXj8's Avatar
Default rear drive side wheel bearing ?? 2000 jag xj8
is it normal to change bearings in pre existing rear hub or just buy a whole new rear hub assembly bearing assembly??? obviously just replacing the bearings and seals is more cost affective but probably a bigger pain in the rear end....advice???
Old Nov 22, 2012 | 01:41 AM
plums's Avatar
... pain in the rear end
Most people here change the bearing. There are how-to's sprinkled around here somewhere.
Old Nov 22, 2012 | 03:48 AM
RidenXj8's Avatar
where should i look ?? can i just search that or do i have to look in the forums?
Old Nov 22, 2012 | 04:17 AM
plums's Avatar
search will work as long as you use the correct words to narrow down your search
Old Nov 22, 2012 | 04:41 AM
RidenXj8's Avatar
cant find anything on how to change a 2000 xj8 rear wheel bearings...help?
Old Nov 22, 2012 | 05:00 AM
xjrsteve's Avatar
Maybe here (only by words):
https://www.jaguarforums.com/forum/x...acement-40191/
Old Nov 23, 2012 | 11:40 AM
RidenXj8's Avatar
any good places for parts???
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
MarathonJohn
Sep 3, 2015 07:59 PM
martybmw
Aug 31, 2015 10:15 PM
peterg19
Aug 28, 2015 08:42 AM
