Rear Lights Stay On/ Car Won't Start with Jump?
Old Feb 17, 2015 | 11:25 AM
Ben7's Avatar
Question Rear Lights Stay On/ Car Won't Start with Jump?
Would anybody know what happen here: I had a problem with the Rear Lights Staying On with the light switch off. I was traveling on the road to a job. I got to my job turn off the key, light switch off and both rear lights still stayed on. I thought I could take the bulbs out because I figured it drain the battery by time the meeting was over. So I took both rear bulbs out. After meeting car won't start, I guess it was still draining battery even with bulbs out? Anyway, car now won't even start with a jump? Any suggestions would be greatly appreciated? I'm stuck out in the country.
Old Feb 17, 2015 | 06:25 PM
plums's Avatar
If a battery is very weak, sometimes it needs to have the donor battery hooked up
for a while to help bring up the capacity before trying to start.
The SLCM, security and locking control module under the trunk fusebox also
controls some of the rear lights. You may have a defective module given the
light bulb incident.
Old Feb 17, 2015 | 07:30 PM
sparkenzap's Avatar
I am with plums. I will bet you drained the battery. Then your jumper cables are probably inadequate, or you have not made a good connection to the batteries with them.
If that is not the case, you may have a more serious problem with the BPM. I sure hope not since they are a PITA to replace.
When you say, won't start", do you mean won't crank? What happens when you turn the key?
Old Feb 18, 2015 | 01:37 PM
Ben7's Avatar
I'll look into both your replies. thanks
When I say won't start... even when turn the key while trying to jump and doesn't even try to start, no sound from starter or engine; its totally dead.
"you may have a more serious problem with the BPM"
Whats the the BPM?
Old Feb 18, 2015 | 06:02 PM
sparkenzap's Avatar
Oh! That might point to the immobilizer circuit!
BPM = Body Processor Module
You might consider getting the car over to bob gauff, "motorcarman", near decatur.
Old Feb 19, 2015 | 09:34 AM
Ben7's Avatar
Question
Mechanic where its broke down at says it needs a Security Locking Module (SLM). And that Jaguar don't make them anymore. And he believes you can't get it aftermarket either? Is that correct? That you have to get them used.
Would any jaguars from the Jaguar Models (Modern) group use the same SLM? Like the XJR (X308)? I assume this one does since my XJ8 is a X308... ?
Or the
(X350 & X358) XJ6 XJ8 XJR
(X305) XJ12
(X300) XJR
X-Type
S Type / S Type R
Old Feb 19, 2015 | 09:57 AM
RJ237's Avatar
Check with ASI to see if they repair them. They are able to repair just about all the modules.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
Old Feb 19, 2015 | 06:33 PM
Ben7's Avatar
Arrow
Do I have to replace with specific same part no. My SLM part no is LNC2600HD where some on ebay are LNC2600HE for the same model jag and years. ('98-'03)?
Old Feb 19, 2015 | 07:06 PM
plums's Avatar
There are some rules with regard to versions.
The word VCATS will appear in the posts discussing it, so search on that.
VCATS refers to a label in the trunk pasted to the spare tire well which
details the exact versions that were installed in your vehicle. If it is
missing, a dealer can bring up a printout of the same data with your
VIN.
There may also be some programming involved requiring access to
IDS/SDD. A dealer and many specialists will have it and it can also
be bought for under $100.
If you've never used IDS/SDD, this is not the time to start learning.
Old Feb 20, 2015 | 06:52 AM
sparkenzap's Avatar
I have installed the SCLM from my MY 99 XJR into my MY 02 XJ8 with no problem whatsoever, except that the fob had to follow the module because they are on a different frequency band. No VCATS match, no reprogramming, nothing. So hit fleabay and buy one for less than $100., preferably from the same model year or get the remote with it and(assuming that is the problem) you will be "good to go". Or call bob.
Old Feb 20, 2015 | 10:05 AM
Ben7's Avatar
Is there any difference between the ones that say LNC2600HD and LNC2600HE?
And if I buy one that doesn't have the remote, would it better to get the HD because thats what mine has on it. Or will the remote I have work with the HE?
Old Mar 6, 2015 | 10:14 AM
Ben7's Avatar
Question
Actually I misheard the mechanic, mine is actually a HB. And I ordered a HE, the car will unlock and drive now but the Key FOB want work; but least I'm able to drive the car. Maybe I'll go back and try to find a HB to get the Key FOB to work. Or get the old one repaired? The mechanic said he tried reprogram the Key FOB with a procedure from youtube but it didn't work. Any suggestions on getting the Key FOB to work?
Old Mar 7, 2015 | 12:12 AM
sparkenzap's Avatar
Yep, as I said earlier, the frequency band of the Fob changed, so you either have to get a fob to match your SCLM, or get a SCLM to match your fob, or get your original SCLM repaired. Check the archives for a repair facility.
BrentGardner
29
Dec 16, 2024 12:13 AM
1964Daimler
Sep 2, 2015 11:41 PM
Sshenton1975
Aug 30, 2015 09:29 AM
Drew2006
Aug 28, 2015 04:22 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
