Rear lights - what's going on?!
Old May 5, 2014 | 05:02 AM
gj1982's Avatar
Default Rear lights - what's going on?!
Hi again
Getting to grips with the many 'quirks' of my xj sovereign...!
When I put the side lights on, the rear main lights come on as well - or is this the brake light? Because when I press the brake this bulb just gets brighter and that's all. Is this right?!
Also - when the lights are off and I brake, the bulb defect light comes on. When the lights are on, the bulb defect light is on constantly unless I press the brake, at which point it goes off!
What's going on?!
Many thanks
Gavin
Old May 5, 2014 | 07:36 PM
mikebaker3's Avatar
Start by checking all bulbs for the tail light assy on each side for burned or broken filaments.
You need to look at a wiring diagram to get the color codes for the different bulbs.
Check the wiring in the trunk for shorts and broken wires.
Old May 5, 2014 | 09:08 PM
sparkenzap's Avatar
From the behavior of the lamp check indicators, I might guess you have a taillamp ground problem. But, as Mike suggested, you should check all of the lamps for bad filaments, and make sure the correct bulbs are installed.
You did not mention the history...
Old May 5, 2014 | 11:48 PM
jimlombardi's Avatar
Check to see if either the right or left tail light stays on all the time.
If this is the case then you might have to replace or repair the SLCM (Security Lock and Control Module), see post# 1 in the following thread:
https://www.jaguarforums.com/forum/x...14/#post909092
Jim Lombardi
Old May 6, 2014 | 12:09 PM
avt007's Avatar
You refer to it as a "Sovereign"- what year is your car?
Old May 6, 2014 | 01:02 PM
avt007's Avatar
I see that this is a double post also in the X300 section.
Old May 6, 2014 | 03:11 PM
Look like it is 1995 XJ6 from his postings in the X300 section.
Jim Lombardi
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
