Rear subframe front bush collapsed ?
Old Sep 3, 2022 | 09:40 AM
Vauxi's Avatar
Default Rear subframe front bush collapsed ?
Hello. To me my car rear subframe front bushes are collapsed? Rubber shoulder doesn't touch the support bracket but there is no much space there. In picture car is standing on its tyres normally. Picture is a bit dark but I think it is usable.
Bush
Old Sep 4, 2022 | 10:16 AM
nilanium's Avatar
I would hold a small mirror above it so you can look down into the top of the bushing, and get a view that way. Or if you're really unsure, you can lift the car up, support the subframe cross memeber with a jack, and undo that side bracket (4 bolts, but these can be tough) to look directly at that bushing.
Just looked at mine, it does have a gap there, replaced maybe 30k mi ago.
Old Sep 4, 2022 | 10:29 PM
Vauxi's Avatar
Thank you for the picture. It was exactly what I was hoping for. I'd say that I have 1/4 of that space you have between bracket and the bush rubber.
Old Sep 4, 2022 | 11:26 PM
Vauxi's Avatar
Took another better picture. I'd say that in near future I'l be shopping new bushes.
Old Sep 5, 2022 | 08:29 AM
RandyS's Avatar
2000 JAGUAR XJR 4.0L V8 Supercharged Subframe Bushing | RockAuto
About $23
Old Sep 5, 2022 | 08:40 AM
Vauxi's Avatar
Yep. Not expensive and not difficult to replace. I might drive my other british car next summer and those bushes ain't that broke yet. So let's see.
Old Sep 5, 2022 | 09:48 AM
nilanium's Avatar
That's for the front subframe, the part number you're looking for is MJA2595AC. ~$30 on Rockauto for URO, or ~$60 on Terry's for OEM.
Old Sep 5, 2022 | 11:01 AM
RandyS's Avatar
Hmmm... Strange that they list the rear bushing under subframe MOUNT.
Old Jun 16, 2024 | 08:13 PM
GeeVeeXF's Avatar
Many thanks indeed for such a full and considered reply. Yes I can with confidence put ticks against the various points you've raised. The car has only just kicked over 112,000km and I service it at every 10,000km or 12 months. For the ultra long drives like my recent 8,500km I actually had a full coolant change and system pressure test as part of a service I had done roughly 500km before the trip and then a simple oil change immediately on return as temperatures were up as high as 40+C.
Touch wood its been an absolute joy of a car.
2008 XF 2.7L diesel
Old Jun 17, 2024 | 12:31 PM
clubairth1's Avatar
Community Influencer
Maybe posted to the wrong thread as you have an XF?
jahummer
Sep 16, 2022 05:20 PM
MCFastybloke
22
Mar 3, 2022 08:44 AM
Melb2018
Jul 10, 2019 12:15 AM
Jagluvr
Jun 7, 2018 04:47 PM
