Reduced performance message
Old Apr 20, 2015 | 04:15 AM
kevin897's Avatar
Default Reduced performance message
Hi. I have a jaguar XJ8 2000. When driving along I am intermittently getting a message on the dashboard Reduced Performance. When i was accelerating past a car just building up speed it happened and the car got on like it was on kangaroo juice. I have noticed sounds that I am not sure are connected. I hear a squealing sound as if a belt is slipping. But I don't notice it all the time. I hear short growling/roaring sound a few seconds on a few seconds off. Again not sure if connected. Crusing at 70mph for 70 80 miles not a problem no messages. But driving on A roads at slower speeds 40 - 50mph the message comes on regularly. Me thinking that it is a transmission issue because it is having to change gear continually. Anybody any ideas or have had this before
Old Apr 20, 2015 | 05:55 AM
Welcome to the forum kevin897,
I've moved your question from UK & Eire Region to X308 forum. Members here with the same model will be able to help.
Old Apr 20, 2015 | 03:31 PM
Sean B's Avatar
Kevin - I'd suggest buying or borrowing an OBD code reader and plug your car in to capture the fault codes. If it goes into restricted performance it logs a code that you can post on here for diagnosis. Any theories at this point are moot.
magmedia
Aug 15, 2019 08:54 PM
jagxk2008
Feb 4, 2016 09:53 AM
Collector1
Sep 28, 2015 03:52 AM
reb1999
Sep 26, 2015 08:41 AM
zdrapec
Sep 25, 2015 05:49 AM
