remote code numbers
Old Jul 3, 2009 | 11:20 PM
Jean-Karim's Avatar
Default remote code numbers
Hi all,
I need to order another remote for my 2001 XJR and I want to make sure I order the right one , so can someone let me know what are the numbers behind the remote I need in order to order the right remote? Dealer told my VIN was showing a remote code : LJE 2610-AB , but what about the other numbers on the back of the remote?
Thank you so much!
Old Jul 4, 2009 | 07:27 AM
Thermo's Avatar
Veteran: Navy
Jean, what numbers are you seeing. Not having a remote in front of me of your style, I'm not sure what numbers you are seeing. I can tell you that one of the numbers that you are seeing will be labeled "FCC ID:" with some series of numbers and letters after it. All that happens to be is a code the US Government has for the particular device indicating that it conforms to a certain frequency range, transmits at a certain power, transmitting a defined set of information.
The big thing that you want to be looking for is the part number (LJE 2610-AB). You meet that, the rest of the numbers on the remote should be identical. Just make sure that the remote has the "AB" on the end. The AB as I recall is the model identifier and over the years, if a change is made to the security system, that gets updated as the data the remote is sending has changed.
Old Jul 4, 2009 | 09:30 AM
Jean-Karim's Avatar
Thank you so much!!!!!!!
philwarner
Oct 4, 2024 01:37 PM
mbergen
Oct 23, 2019 10:26 PM
cissdm
May 3, 2016 06:02 AM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
