Remote control
Old Feb 18, 2011 | 10:57 AM
c5cruiser's Avatar
Default Remote control
I installed new batteries in my remote for my 99 XJ8 and now it will not work.
I installed the batteries correctly and the tester at the parts store shows that it is transmitting.
When I install new batteries in the remote for my Corvette the car has to recognize the remote. Is this the same with the Jag? I went through the owners manual an nothing is said except for what it can do and how to use it. Anyone know how to make these two communicate?
Old Feb 18, 2011 | 11:33 AM
Sean B's Avatar
Yep same as the vette' - search on here keyfob programming, it's something like key in ignition to position one holding the headlamp flash on, then flash 5 times to enter learn mode, an led will flash on the gearbox bezel, press the remotes you want to pair.
Old Feb 18, 2011 | 12:22 PM
vdpnyc's Avatar
$125 at the dealer or 10-seconds of your time... lol...
Leave the drivers door open and put the key in (don't turn though)
Pull back the high beam then turn the key to the first (or maybe second?) position (don't start the car)
Release the high beam and quickly flash the high beams 4 or 5 more times until the car makes a beep
Now press any button on EACH remote that you have (the car should beep for each one).
Take out the key and everything should be back to working.
Yes, the Jag dealer really quoted me $125 beforeI learned how, total crooks...
Old Feb 18, 2011 | 12:42 PM
vincent661983's Avatar
HI C5,I was about to give you the same instruction.trust our members. It works as I follow the same instruction found here.
just try a few more times and you will feel so happy that you are able to program your own car remote.
Old Feb 20, 2011 | 01:27 PM
c5cruiser's Avatar
I followed the instructions and was able to make the car chirp but when programing the remote it beeped twice one button but still would not lock or unlock the car. It seems to make that sound (2 beeps) as soon as I take the keys out. I take it that it means that it is finsihed learning.
Any ideas?
Old Feb 20, 2011 | 02:37 PM
c5cruiser's Avatar
I just checked the batteries without a load on them. One was at 2.94VDC and the other was at 1.58VDC. I can't imagine that 1.48VDC would make a diference.
Old Feb 20, 2011 | 02:54 PM
ttl's Avatar
ttl
I don't know what the batteries are, but it sounds like they're nominally 3V. If so, the second one is probably dead (even if it's new). Might want to try another one.
Old Feb 20, 2011 | 07:20 PM
c5cruiser's Avatar
SON OF A BEES WAX!
That should teach me to never, EVER trust new batteries. I bought amother set and now it works just fine now. I wish I had the receipt but I'll just chalk it up to expereance.
Thanks everyone for their input. If it wasn't for this I would have never known how to program the keyfob.
Now if I could only find a good deal on getting a spare key.
Old Feb 21, 2011 | 08:21 PM
vdpnyc's Avatar
batteries?? Not battery (one) ? My fob has just one in it, I took it completely apart for cleaning once...
Old Feb 21, 2011 | 09:42 PM
c5cruiser's Avatar
Correct.
Mine had 2 in it and my owners manual shows that it needs 2 CR2016 also.
Old Feb 22, 2011 | 12:11 AM
vdpnyc's Avatar
What year is your car? Does the remote look like:
ryan_border
Dec 23, 2015 04:27 PM
carl purchase
Oct 14, 2015 06:14 PM
danke
Oct 3, 2015 09:31 PM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
