Removal of center console--2003 Jaguar xj8
Old Apr 19, 2008 | 10:03 AM
jag_genius's Avatar
Default RE: Removal of center console--2003 Jaguar xj8
put in neutral remove j gate surround.. carefully or it will brake.. then once off.. two 7 mm nuts and two 7 mm bolts..then remove plastic black surround and unplug sport switch..then pop wood out carefully.. then the wood around the center vent needs to be popped offabove radiothen remove2 torqs.. then at the back of the center console.. there is a vent.. pop it out with and unplug any connectors.. then remove 2 more torqs then slide console back and out.. then unplug ashtray connector..thens its off.
stanjag
Dec 29, 2024 08:26 PM
flyc2c
Jan 15, 2016 05:30 PM
MarathonJohn
Sep 3, 2015 07:59 PM
PinnacleWax
Detailing / Car care
Aug 26, 2015 11:44 AM
souldoubt
Aug 25, 2015 08:15 PM
