Removing 2001 Xj8 trans control unit cover ???
Old Jun 9, 2018 | 03:19 PM
zagamuffin's Avatar
Default Removing 2001 Xj8 trans control unit cover ???
have discovered strange reverse type screws holding the cover on under the bonnet , is their a trick to remove as don’t have a tool ???
Old Jun 9, 2018 | 03:31 PM
Sean B's Avatar
A large flat head screwdriver works, but slow going. Once out you can replace with regular screws/bolts with more orthodox heads like torx or pozi.
Old Jun 9, 2018 | 03:40 PM
zagamuffin's Avatar
cheers lad
Old Jun 9, 2018 | 03:55 PM
flay's Avatar
I used a grinder and a dremel to make space for a flat screwdriver.
Old Jun 9, 2018 | 04:13 PM
zagamuffin's Avatar
Flay
hard to get into the recess surely
Old Jun 9, 2018 | 04:50 PM
flay's Avatar
oh, I forgot, I used this method to remove first the screws from the bracket on the engine's ECU. First I took of the bolts of the plastic cover same way Sean told, then I used the grinder to make them more easy to be handled.
Old Jun 9, 2018 | 05:52 PM
zagamuffin's Avatar
Sorted guys , jagforum comes up trumps
Digitron
Dec 23, 2017 10:50 AM
RSpi
Jan 23, 2015 05:59 PM
MCW739
Dec 29, 2014 01:16 PM
OCG304655
Jul 12, 2013 08:18 PM
anoojra
Jan 30, 2010 06:01 AM
