98 XJ8 engine control unit
Old Jul 3, 2013 | 12:37 PM
OCG304655's Avatar
Default 98 XJ8 engine control unit
Hello, I am working on a 98 XJ8 for a friend. It was running great and the next morning it would crank but not fire. I've checked all the fuses that control coil pacs and fuel injection. All are good. Plugged my code reader in and got a P1000 code, indicating a faulty Engine Control Unit. The reader also said it couldn't complete testing.
Have looked on ebay and see many ECU's with the same part number as this one. Will these work without reprogramming from the dealer?
Are the ECU's on this model known to fail or should I be looking elsewhere, like maybe the crank position sensor?
Old Jul 3, 2013 | 12:46 PM
Welcome to the forum OCG304655,
DTC P1000 does NOT indicate a faulty ECM on a Jaguar. It is the code for OnBoard Tests not completed since last memory clear. You will always see either P1000 for tests not completed or P1111 for test completed.
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 section for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You can also visit the US Southern MidWest Region section by following this link Southern MidWest - AR LA MS KY TN AL - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Brutal's Avatar
One welcome and this is in the wrong section for tech help. But here. P1000 and (P1111) is/are a "readiness" codes or lack there of. Not a ecu failure. Did you check fuel pressure? A bad fuel pump is morelike for a crank no start than a crank sensor. But that would be next to look closer at
Old Jul 3, 2013 | 01:54 PM
Old Jul 4, 2013 | 09:23 AM
welcome to the forum
Old Jul 4, 2013 | 09:49 AM
WhiteXKR's Avatar
Lots of correct and excellent advice is give above. There is a schrader valve on the fuel injector rail. If you do not get a strong squirt of fuel when you depress it after cranking you probably have a failed fuel pump.
Old Jul 12, 2013 | 08:18 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
toronadomike
Jan 22, 2026 10:13 PM
tberg
Sep 7, 2015 07:32 AM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
GreyXK
Aug 31, 2015 05:15 PM
