Removing trim on sliding roof
Old Nov 6, 2025 | 12:11 AM
Jeroen's Avatar
Default Removing trim on sliding roof
A friend of mine has just bought a very nice 1998 Daimler. Very nice car, in many ways identical (technically) to my own 2003 XJR.
We want to adjust the sliding roof; it leaks, and it doesn’t sit flush with the roof. I have the 1998 workshop manual, and it has a procedure for the removal and alignment. However, you need to remove the trim on the inside. The manual refers to two procedures, as I can see, 501-17 and 76-82-19.
Can't seem to find them either in the workshop manual. Does anybody have these procedures or know how to remove the trim from the sliding roof?
Jeroen
Old Nov 6, 2025 | 07:32 AM
RandyS's Avatar
https://redirect.viglink.com/?format...Viewing%20Page
Old Nov 6, 2025 | 07:42 AM
Cafcpete's Avatar
You really don’t need to remove the trim panel.
You want to look at TSB 13-34.
Removing the trim is only to give you access to the location where you place the 8mm drill, and you really don’t need to do that.
This is simply the fully shut location, and you can see when it is shut.
Use a stright edge on the roof if you need to whilst manually adjusting the motor.
Once it is properly shut, then take the control module and align the dots.
Its not to hard, but be careful at step 7
Old Nov 6, 2025 | 02:02 PM
Jeroen's Avatar
Many thanks! Successfully removed the trim. Re-alligned the sun roof and put everything back together. Roofline is all nice and flush!
Jeroen
Old Nov 6, 2025 | 03:26 PM
RandyS's Avatar
That's great news and we are sure it feels better knowing the rain is kept at bay.
edwin.koh
General Tech Help
Jul 8, 2024 06:31 PM
Khan
Jul 8, 2022 08:50 PM
paddyx350
Jun 6, 2022 08:32 AM
Danomar200
Jan 30, 2015 09:08 AM
Michigan
Aug 28, 2008 10:45 PM
