replace switch bulbs
Old Oct 2, 2013 | 04:28 PM
StevenC's Avatar
Default replace switch bulbs
Hi Peeps,
I've just joined the forum tonight, I'm looking for advice on how to change bulbs behind the switches on my climate control unit on my 2002 XJ8 SE.......as some of them do not illuminate....
Thank you in advance
Steven C.....from Edinburgh, Scotland
Old Oct 3, 2013 | 08:01 AM
StevenC's Avatar
My question probably is, do the fronts just pop off the switches to change the bulb behind them
Old Oct 3, 2013 | 07:29 PM
Sean B's Avatar
Welcome to the board Steven.
Youtube is a belter for accessing these switches - you'll need to remove the shifter surround and ski slope (reverent sam a member on here posted how on youtube), then unscrew the switchpacks you need to access. Be careful with the connector blocks, and have the battery disconnected for safety instead of finding blown fuses...
Jaguar supply the bulbs, I went to the extreme of replacing every bulb with led's, all soldered so I never have that job to do again
Old Oct 4, 2013 | 04:14 PM
StevenC's Avatar
Hi Sean, thanks for the info..........
I took out the ski slope the other day, then removed the screws holding in the radio and climate control unit..I then tried to pull both units from the dash. I gave up as they weren't for coming out easily.... is there something I'm not doing......or should they come out with ease ?
Old Oct 6, 2013 | 11:58 AM
StevenC's Avatar
When you say remove the ski slope, does that mean the whole leather centre consul or just the walnut insert...
Old Oct 7, 2013 | 01:08 PM
Maninahat98's Avatar
Just the walnut insert, then undo the screws that hold the module in, 4 I think....Do a seqarch and there's some picks on the forum too.....Allan
Old Oct 7, 2013 | 02:26 PM
StevenC's Avatar
Thanx Alan
Quick question, do the fronts pop of the switches individually to change the bulb behind them ?
Old Oct 7, 2013 | 03:25 PM
Sean B's Avatar
Thanx Alan
no, twist out's from the rear, did you find the top screw above all the switches, it's kind of hidden. It shouldn't be difficult once you've unscrewed them.
Old Oct 8, 2013 | 10:18 AM
StevenC's Avatar
Will have another go at the weekend......Thanx
Old Feb 17, 2014 | 04:08 PM
pingj's Avatar
Sean, where did you get the LED's and what color did you use? How did you solder in the LED's
LED's are typically brighter than standard incandescent bulbs. Did replacing the bulbs with LED's make the switches too bright?
D.K
Dec 10, 2023 02:05 AM
allenman85
May 10, 2021 03:11 PM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
