replacement seatbelt problem
Old Aug 6, 2015 | 11:29 AM
here I go again's Avatar
Default replacement seatbelt problem
Hello everybody
This is on my wifes 2002 XJ8. the passenger seatbelt jammed up so I removed it and was going to replace it with one from my 2000 Jag that I parted. I cannot get the latch pawl to release so I can pull the seatbelt out. Neither car has been in an accident. What is the trick? Did I screw up when I removed the unit from the parts car and let it go all the way in? Or?
Thanks you in advance!
Old Aug 10, 2015 | 12:31 PM
Anybody?
I cant believe that not one person has had this happen to them. It would figure my luck though.
Hopefully I can get an answer.
Old Aug 10, 2015 | 06:03 PM
mustangtyson's Avatar
Try hooking up the battery and hitting the brake pedal?
Old Aug 10, 2015 | 07:40 PM
andrew lowe's Avatar
Originally Posted by here I go again
Anybody?
Hold the seatbelt unit as near as possible to its fitted orientation, both north/south, east/west, then GENTLY try to pull the belt out.
You have to be patient, and gentle, while moving the unit very slowly/gently left/right, forwards/backwards... it will, with some/a lot of patience become free, the trick is slowly/gently, after a handful of chill pills.
DO NOT clang it, bang it, shake it, throw it across the workshop, or swear at it, because all that does is make it mad and even more stubborn to undo!
Old Aug 11, 2015 | 12:35 PM
Thank You
We are trying it now and will report shortly.
thanks again!
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
martybmw
Aug 31, 2015 08:41 AM
Sivert
Aug 26, 2015 05:15 PM
