Replacing fore/aft seat motor and gearing
Old Apr 30, 2021 | 11:48 PM
pcolapacker's Avatar
Default Replacing fore/aft seat motor and gearing
My driver's seat does not go fore and aft. The switch works in both directions and the motor spins, but the output shafts from the motor do not turn. Thinking of switching motor/gearing with passenger seat. Passenger seat can stay all the way back until I fix or replace. Anyone do this?
Old May 1, 2021 | 10:16 PM
Highhorse's Avatar
Bookmark this site... https://shop.everydayxj.com/Default.asp ...Dave's a good guy and comes up with a lot of NOS parts. Don't be afraid to contact him if you don't see what you need.
He has NOS seat motors toward the bottom of the X308 section... https://shop.everydayxj.com/XJ8_XJR_...003_s/1841.htm
Old May 2, 2021 | 08:53 AM
Vonnslingo's Avatar
So before you do that maybe you can test to see if you’re gearing‘s OK bye putting a cordless drill on the cable that comes out of the motor. If the gearing is good the cordless drill will make the seat go up and down. I went through this a month ago they’re a little bit complicated but if your motor is spinning your cable might not be in all the way
Old May 2, 2021 | 08:59 AM
Vonnslingo's Avatar
Old May 2, 2021 | 12:22 PM
Highhorse's Avatar
Good little nugget to know...
Old May 2, 2021 | 08:17 PM
Default Update
Motor good. Bench tested. One of the tracks was jammed. Could only turn with a vice grips. Other turned by hand. The worm gear in the gear box stripped the plastic gear.
Old Dec 29, 2023 | 07:08 PM
cdma's Avatar
Have this same issue. Anyone know how to remove the gear without drilling out the rivots
manycars
Mar 13, 2016 12:40 PM
Steve274
Aug 6, 2015 08:00 AM
MK2
XJ40 ( XJ81 )
Dec 13, 2014 06:15 PM
wyxtype
Jul 6, 2014 06:41 AM
awil
Jun 3, 2014 12:56 PM
