Resivor tank on 2006 XJ8 leaking.
Old Apr 27, 2025 | 07:48 PM
leftydoc's Avatar
Default Resivor tank on 2006 XJ8 leaking.
Hello new to forum and have been reading similar threads on this subject. Top hose nipple cracked and tank needed to be replaced. Worked through all the challenges to get the old tank out and new in. All was going well until attaching bottom hose on to tank. I put it on but every time it leaks on bottom of fitting. Been careful with the wire clamp and it looks like every thing is good but still leaks. Any help would be appreciated. Thanks
Old Apr 27, 2025 | 09:07 PM
Gator8's Avatar
This forum is for XJ8s through 2003; you’ll find better information on the X350 forum for your car. Thanks and good luck.
Old Apr 28, 2025 | 12:20 AM
xalty's Avatar
put the clip in the closed position, lube the o-rings and make sure it clicks.
Old Apr 28, 2025 | 07:30 AM
leftydoc's Avatar
Thanks for the replies, I will post in that area from now on. I did put clamp on first and then seat it. Thought I heard a click but I did not use any lube for the o rings. Thanks
kafoltz
Dec 18, 2021 04:53 PM
cityboy
Oct 20, 2021 09:21 AM
Plant
Jun 18, 2013 01:08 AM
cliff328
Aug 19, 2012 10:02 AM
cdmarano@gmail.com
Jul 27, 2008 08:54 PM
