Restricted performance
I've got the dredded restricted performance light on the dashboard...I have had a diagnostics on the car codes are as follow
P0336 Crank Shaft Sensor A (where is this? pics would be a great help)
P0352 Ignition Coil B Circuit Malfunction
Are these connected under the Hood/Bonnet to the ECU via the same connection?
Thanks in advance for your help.
