Roof Opening Panel Shield (Sunroof Headliner)
Old Jul 27, 2021 | 02:34 PM
pcolapacker's Avatar
Default Roof Opening Panel Shield (Sunroof Headliner)
Going to have my headliner redone. Trim shop will charge a little less if I pull sunroof headliner myself. Also, although they are a well known shop, rather due myself than have someone muscle it out. Found in workshop manual how to remove front two-thirds. Searched but I can't find out how the back one-third comes out.
Old Jul 27, 2021 | 04:07 PM
aquifer's Avatar
You're talking about removing the fabric headliner from the sunroof panel itself, correct? That job couldn't be easier. Flip open the sunroof (flip it up in the back), get out of the car and grab the headliner panel through the opening on the roof, and pull straight back. It is held in by spring clips, and will slide out over the roof of the car when you pull on it. Make sure you pull both sides evenly.
Old Aug 21, 2021 | 01:47 PM
Default Help
Larger front portion came right out by sliding back when tilted open. Still can't figure out how to remove the back smaller portion with the rain gutter. Have to take off sunroof?
Old Aug 21, 2021 | 01:55 PM
xalty's Avatar
break the back section and then take the front two metal clips off
or bolt the roof off and undo the back section, i forgot how to do it the right way
Old Aug 22, 2021 | 01:30 PM
Default Figured it out
Remove sunroof (six torx bolts). Remove metal clips at rear (see picture). Gently pry up plastic clips at front.
LT1 jaguar
Jul 1, 2021 05:11 PM
OUScooby
Apr 24, 2020 02:43 PM
Scotlad
Dec 4, 2017 10:25 PM
thomash85715
Aug 27, 2016 06:24 PM
DayOff
XJ40 ( XJ81 )
Sep 17, 2014 11:01 AM
