Rough idle issue
Old Mar 24, 2010 | 12:28 AM
wayne1991's Avatar
Default Rough idle issue
My car started where it would lag when at full throttle, but now it no longer lags when i give the car acceleration. The car however, runs smooth but then i will feel the car engine shake for a second or two and then run smooth again. I think this is a misfire but i do not have any OBD2 codes. Does this mean it needs new spark plugs, or is there something else wrong?
Old Mar 24, 2010 | 02:02 AM
JWT's Avatar
JWT
Wayne,
You could take it in and get it scanned at an auto parts store in your area. Many of them offer that as a free service. Even if there is no check engine light, there may be a pending code or the misfire test may show as failed. If that is the case, you would probably get a check engine light and misfire code pretty soon. It sounds like a misfire in your description, but it should throw a code if it persists. It must be quite intermittent for it not to.
A can of injector cleaner could also be an inexpensive first step. I am told the GM injector cleaner is very good. You could check the plugs too, especially if they are overdue. I have been told they tend to create problems at higher engine speeds or during acceleration. Sorry, I have never really had a bad plug, having replaced them before failure. (still overdue though). I am not an expert at bad plug symptoms. I had an occasional misfire that ended up being a coil. It would run fine for weeks and then start missing, then run fine for a few weeks. It did throw misfire codes when it did that. I eventually determined it was a coil. Of course I replaced plugs first as it was a less costly first step, but did not turn out to be my problem.
Again, if it is misfiring, I would expect a code to appear fairly soon. The computer only tolerates so many before coding. There are many possible causes for rough engine. It would probably be a bit easier if you did get a code.
Good luck
Rivguy
Dec 4, 2020 07:55 AM
GordoCatCar
Jan 2, 2017 01:10 PM
joesoap
Sep 10, 2015 01:09 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
Bowman
Sep 3, 2015 03:17 PM
