ruff idle after k&N intake problem
Old Jul 29, 2011 | 09:33 PM
Jag-man's Avatar
Default ruff idle after k&N intake problem
Hell all. I'm sure its been posted before but i need help with my jag ASAP. I have a 03 xjr and after K&N intake it ran fine for the 1st few days but went to drive today and it sound like its going to die and i dont want to damage anything. I know i can alway put the factory one back on and hope that fixes the problem but i allready paid for the k&n and would rather use it. If anyone has experienced this before or nows a fix please let me know. Thanks
Old Jul 30, 2011 | 04:29 AM
Sean B's Avatar
Some K&N filters are loaded with an oil to catch debris, I think it can effect the mass air flow sensors within the intake tube.
Try and clean the MAF sensor with an electrical contact cleaner spray, you'll need to remove it from the sensor housing with two posi drive screws, wiggle it out.
Another thing it could be is an air leak, so check your install also, as it only takes the induction tube to sit on the throttle body slightly uneven to induce a leak.
Old Jul 30, 2011 | 07:18 AM
Jag-man's Avatar
sean thanks for the info i check for the leak since i put the new filter on it does pull the induction tube down more so it could be causing a leak at the TB. Thanks again
Old Jul 31, 2011 | 06:29 PM
Jag-man's Avatar
Ok icleaned mas sensor and made sure no leakes at TB and no car starts fine but dies right after like its not getting enough gas. i tried putting the pedal down al= light to keep it going but dosnt help. I need some help guys. anything would help. Thanks
Old Jul 31, 2011 | 09:03 PM
MidlifeXJR's Avatar
Your issue might be unrelated to the K&N, it actually sounds like a fuel pump issue. There are two fuel pumps on the XJR and when one dies, you can experience your exact symptoms. I would get the fuel pressure checked on the rail.
Old Aug 1, 2011 | 12:05 AM
QuadManiac's Avatar
Go back to stock unit... if problem persists, time to look elsewhere.
Old Aug 1, 2011 | 12:24 AM
plums's Avatar
Since you are trouble shooting, you start by baselining your configuration
That means putting the stock system back on to eliminate the differences.
If it works, you have a problem with the K&N or the way you installed it. If it does not work, you have eliminated one possible source and can move on to look for other problems, such as the one suggested by midlifexjr.
edit: Quadmaniac has said just about the same thing in his post above.
Old Aug 1, 2011 | 08:17 PM
Jag-man's Avatar
Thanks for the input i guess back to stock it is. If that dosnt work fuel pump check next.
Old Aug 2, 2011 | 03:11 PM
Sean B's Avatar
Also, the maf is super sensitive to variations, I would do a hard reset as a matter of course on doing something like adding a K&N, the hard reset re calibrates the throttle body, yours sounds like it's still running an engine map with the old filter.
Old Aug 5, 2011 | 09:36 PM
Jag-man's Avatar
Here is an update. Did hard reset and no change. put factory intake back on and no change. Did hard reset again with factory intake and no change. so, not going well
Old Aug 5, 2011 | 10:28 PM
dsnyder586's Avatar
Check to make sure MAF connector is seated
Check to make sure hose from intake to valve cover is attached and snug Any cracks etc?
Check to make sure the intake pipe is tight to the throttle body
Check to see if the vacuum tubes under the air filter box have been disturbed/broken
Check CPS/connector to see if it is dirty...
The fuel rail does seem to be a good place to check since the car ran fine for a few days....
Also check fuses....
All of the above should not take more than an hour and will eliminate alot of possibilities.
Old Aug 6, 2011 | 10:45 AM
luc's Avatar
luc
Not sure because the fuel pumps on the XJR work in the following way:
1/ when turning the ignition ON, pump #2 energize for a few seconds to built up pressure and then is turned off.
2/ Pump #1 in turned on at cranking and stay on.
3/ Pump #2 is turned ON at about 4000rpms to add fuel
4/ If pump #1 is defective, ( based on electrical load, not fuel flow) pump #2 stay on after step #1
Old Aug 6, 2011 | 04:48 PM
Jag-man's Avatar
thanks for the input dsnyder, i have checked all the hoses and everything is snaped on tigh. The hose going from the intake to the valve cover had some oil in or around the end that ataches to the valve cover. is that suppose to have that? i thought about spraying the MAF cleaner on the contacts of the plug for the sensor but wanted to make sure it wouldnt hurt it first. the little red light on the dash was on before withe K&N but went off after i put the factory one back on then after a few tries of starting it the red light came back on but im not getting any other lights or warnings.
Old Aug 7, 2011 | 12:25 AM
dsnyder586's Avatar
Crankshaft position sensor clean and connected tightly?
I have heard of more than one person having start/run issues when that went bad. I replaced mine the day I purchased my XJR.
Old Aug 7, 2011 | 03:13 AM
QuadManiac's Avatar
How long have you driven with either the K&N, or now back to stock, before determining that it isn't running properly? The computer will take some time, during drive time, to reset the fuel mixtures to optimize for any change.
Old Aug 7, 2011 | 09:17 PM
Jag-man's Avatar
It ran for days fine on the k&N then i went to drive it and it started but was running ruff so i didnt drive it. after a few more days it would start but then die right after.
Old Aug 7, 2011 | 09:36 PM
Jag-man's Avatar
No i havnt done anything with the crankshaft position sensor but will add it to the list of possabilities. any advice on how to clean or replace it. the only diagram i could find of it shows its on the back side of the engine near the cabin and looks like it might be hard to get to.
Old Aug 7, 2011 | 10:00 PM
sparkenzap's Avatar
It is on the bottom of the bell housing, hidden a little by the steering rack.
Old Aug 7, 2011 | 10:39 PM
Jag-man's Avatar
ok thanks.
Old Aug 22, 2011 | 09:16 PM
Jag-man's Avatar
ok guys my mechanic has been looking it over and cant seem pin point it. I checked all fuses under the hood and all good. he said the fuel pump dosnt have any drop in electrical current he is also going to check the fuel pressure. any other advice or ideas i could go over with him? i need all those years of jag experience from everyone please. Thanks
