Seat memory - missing potentiometer
Old Mar 30, 2020 | 01:37 PM
Jackson_Dkmg's Avatar
Default Seat memory - missing potentiometer
Hi
I finally took the time to look into the seat memory malfunction, assuming it would be the common problem with the potentiometer.
After removing the back cover, I realized the issue is simpler : there is no such element.
I'm guessing that at some point, either the seat was replaced or the door itself.
Anyhow, I suppose that to restore the functionality, all I require is mounting this potentiometer. Part number is JLM21119 if I'm correct.
Can't seem to find it on sale anywhere however, except at a crazy $250.
Any hints?
Old Mar 30, 2020 | 06:47 PM
Highhorse's Avatar
Here's another # to try.. JZM100007 ...but its also a discontinued item. It also comes up as a nut spring depending on the site.
Sounds like your going to have to go recycle yard hunting if you don't want to pay $250? But compare it to how many Euros it is on this German site.... https://www.teile-profis.de/page_1_3.php#oeformo ...$250 is a steal.
Old Mar 30, 2020 | 08:47 PM
M. Stojanovic's Avatar
And it's a used one (Jagbits). There are two seat bases with motors and potentiometers on Ebay UK - https://www.ebay.co.uk/itm/JAGUAR-XJ...1&isGTR=1#shId and https://www.ebay.co.uk/itm/JAGUAR-XJ...MAAOSwIh5eFMhP at GBP 70. each. You can contact the seller and ask whether, if you buy the whole base, he would be willing to remove the three motors, two gearboxes and the potentiometer and send you only those in which case the shipping should be much lower than sending the whole frame. You can keep the motors and gearboxes for spare.(or sell them on Ebay).
Old Mar 31, 2020 | 02:05 AM
Thank you both for the tips, I'll look into it !
EJ Garity
Aug 17, 2015 12:09 AM
DonsXJ8
Oct 17, 2014 11:43 AM
sogood
Mar 29, 2014 06:02 AM
Tiberious
Feb 29, 2012 06:42 AM
Bill Filek
XJ40 ( XJ81 )
May 31, 2010 09:03 AM
