Secondary chain tensioner problem
Old Mar 6, 2011 | 10:01 PM
  #41
tomjagxj's Avatar
non advanced to advanced position=turn clockwise 60 degree,right?Thanks sparkenzap!
Old Mar 7, 2011 | 12:16 AM
  #42
tomjagxj's Avatar
Read test point's threads for tempest"The other thing that makes noise in that area is the Variable Valve Timing units on higher mileage cars. It is often described at a 'ticking' above idle. Fix is to use higher viscosity oil".
how about 10w40?and how does VVT make noise?Can anyone tell me the detail?!I really want figure out where my car noise come from!HELP!
Old Mar 7, 2011 | 02:11 AM
  #43
plums's Avatar
Originally Posted by tomjagxj
That's OK Sparkenzap.The noise sound like the chain contact the tensioner.when started it ,got 50 second sound,then gone,but after the car getting hot(about 10 minutes),noise come back,in that 10 minutes,even I accelerated 5000 rpm,no sound,everything is ok.After noise back,rpm up noise down,idle is the worst,but you can't hear inside car with fan on or turn signal.
Very late to the party ... but
Your trouble seems now to be RPM sensitive.
now:
higher RPM = higher oil pressure
and:
the tensioners and vvt are dependent on oil pressure
but:
they usually work ok at idle because there is no leakage
so:
look at the joints where the oil might leak out, for example between tensioner and cylinder head. perhaps you did not clean the surfaces or they are not flat.
In addition, you may have a bad tensioner straight from the box. BTW, there is supposed to be a ratchet system on the tensioner that is meant to keep the tensioner from retracting as it wears. It doesn't get mentioned much. Apparently it is a bad idea to push in on the tensioner piston "just to see how it works".
Old Mar 7, 2011 | 01:40 PM
  #44
tomjagxj's Avatar
Smile
Thanks plumsauce!It's not late for party,problem still there.I thought about oil pressure,changed 10w40 instead of 5w30,seems not work.Would you please tell me how I can check leaking between tensioner and cylinder head and know the surface is flat?Thanks again!
Old Mar 7, 2011 | 05:04 PM
  #45
plums's Avatar
Unfortunately, that is a job for eyeballs.
You want the mating surfaces of the parts where the oil passages meet to be clean and flat.
At a guess, on the tensioners you can loosen the bolts and pull them away to look at the surfaces without having to actually remove them. That would save undoing sprockets or lifting of cams. You just want to get a look.
When you go in again, look to see that the tensioners have actually expanded to meet the chain at the movable end. They should be at least close if working properly.
Is there a gasket involved in the vvt that got forgotten?
Did you ensure that you have the correct tensioner? The left and right are different. And ... "left" is as viewed from the driver's seat, not as viewed from the front of the car.
And still, the part may be defective.
Old Mar 7, 2011 | 06:06 PM
  #46
ttl's Avatar
ttl
Interesting point. On the driver's side, the springy shoe is up, and on the other side, the springy shoe is down. (Fixed shoe on tensioned/driven chain side.) If I recall correctly, the castings are also marked "LB" and "RB" (left bank, right bank).
Old Mar 7, 2011 | 07:33 PM
  #47
tomjagxj's Avatar
Hi guys,I will go in there again and check it."in fact I changed two tensioners on this side.First one I put in(with short bolts) totally no working.I pulled out and found it come to parts,I think it's a bad one,then I asked the shop(they order the tensioner for me),they told me the part is ok,maybe I didn't put some oil in it first.I install it again with oil,but same thing.I open my cover again and get it,I bring it to the shop ask them change one for me.They don't,they still think it's good one,maybe I made a mistake.They said I have to buy another one, if new one working fine then they can return my money(ca$120).No choose,I bought another one and put in and it's working like that,much better".I have a "RB" in my hand now,will change passenger side later.But I want fix drive side noise first.More ideals please!
Old Mar 10, 2011 | 11:55 PM
  #48
tomjagxj's Avatar
Hi pd! I hope can read these threads and help me!
Old Mar 11, 2011 | 12:12 AM
  #49
plums's Avatar
And now as I re-read the post, I may be bassackwards. But, they *are* different from side to side.
Old Mar 14, 2011 | 11:32 PM
  #50
tomjagxj's Avatar
Hi guys,bad news,my left side chain broken!Tensioner broken into piece(new second one).I'm worry about pistons and valves now.So,who can tell me how to test them are good or bad in easy way.Thanks!
Old Mar 15, 2011 | 12:14 AM
  #51
sparkenzap's Avatar
Woe, Tom. I would sure like to know the failure mechanism. Any idea?
Old Mar 17, 2011 | 06:00 AM
  #52
jaginblack's Avatar
Which chain broke, primary or secondary? Compression check can quickly reveal valve damage, but can't be done until the chains are all back to normal.
What was the circumstances of the break - in the driveway or going 70? My secondary chain broke in the drive way on startup and I had no valve or piston damage.
If only the secondary chain broke, I would repair the chain and tensioner, set the timing, and do a compression check before starting. Disable spark or fuel when cranking.
Reading over your posts, I would want to know the mystery noise isn't coming from a primary chain rail being broken. If you have a primary chain problem you will have a hard time getting anything else to work right until it is fixed. Could also explain why your secondary parts are failing. The whole chain system needs to be dead nuts in sync and tensioned.
Make sure all the pieces of your tensioner are accounted for...
Old Nov 29, 2011 | 02:26 AM
  #53
tomjagxj's Avatar
Hi everyone,"long time no see"! Very busy these months.But i found that valves bent(two of them).I will replace them next month,then will post some pics here,hope can help someone. Thanks guys!
Old Nov 29, 2011 | 10:29 PM
  #54
sparkenzap's Avatar
do you need some valves? Which ones? PM me- Price is right.... like zero
Old Jan 8, 2012 | 03:34 PM
  #55
tomjagxj's Avatar
Hi guys,I don't need valves now.I think I need a engine.Rebuild that head need $1000.A used engine:jag $2k and ford $1k.Here is my question:May I use Ford one(3.9L)? Any ideas? Maybe I need make a new thread "XJ8 engine change",so everyone don't need read all above it.
RoyLittle0
May 25, 2023 02:38 AM
Dicque
Sep 19, 2015 12:53 PM
Bowman
Sep 15, 2015 06:54 AM
nitrolouie2142
Sep 5, 2015 01:55 PM
Bowman
Sep 3, 2015 03:17 PM
