Secondary tensioners question
Old Aug 20, 2018 | 04:55 PM
buttercup26's Avatar
Default Secondary tensioners question
Just received secondary tensioners set and installed 1 side. They don't seem t keep chain as tight as one I replaced. Is this to be expected?
Old Aug 20, 2018 | 06:47 PM
RJ237's Avatar
Yes. I assume you pulled the pin. Once the oil is up to pressure it will be okay. Note that you are supposed to turn the engine over with injectors disabled to get oil pressure in the system.
Old Aug 21, 2018 | 08:56 AM
avern1's Avatar
The easiest way to shut off the fuel to the injectors is to hold the accelerator pedal alway down on the floor before and duriing cranking. This shhuts off fuel to the injectors and allows cranking to build oil pressure before first start up.
Old Aug 21, 2018 | 06:55 PM
Great, ws studying how to disconnect injectors 2 great tips.
Namor
Jan 21, 2012 09:12 PM
Roos50
General Tech Help
Jan 18, 2010 06:45 AM
wilson18067
Jul 22, 2008 06:54 PM
JimT
Jul 8, 2008 04:51 PM
