Should both cooling fans come on when I use the AC
Old Sep 7, 2016 | 01:00 AM
cdc's Avatar
cdc
Default Should both cooling fans come on when I use the AC
Trying to track down my air condition problems and noticed that only 1 fan spins when I put the AC on.
Should they both be on?
Old Sep 7, 2016 | 06:15 AM
RJ237's Avatar
Yes. There have been several threads here and on XK8 forum recently, so a search should provide you with assistance.
Old Jun 13, 2019 | 06:04 AM
larys192's Avatar
Any links to those articles? Cant find nothing
Old Jun 13, 2019 | 07:45 AM
Samilcar's Avatar
The slow mode kicks both fans on at 174psi A/C pressure, fast mode (both fans again, but full speed) kicks in at 326psi. If A/C high-side pressures are below 174 (which would happen if outside temps are relatively cool), both fans should never run. I would suspect that one of your fans is inoperative.
https://www.jaguarforums.com/forum/x...r-shop-199844/
SCMike
Sep 17, 2016 07:56 PM
geekman
Sep 14, 2016 10:41 PM
AltaHeights1
Sep 7, 2016 04:49 PM
a4500435
Sep 2, 2016 06:19 AM
Tink
Sep 1, 2016 01:04 AM
